I Hope VDJ readout the CDJ2000's player ID's (Player Number) over USB to connect the CDJ's to the VDJ Deck's. I have four CDJ2000's connected via USB-Hub to MAC or PC and used a 4-Deck Skin of VDJ but the CDJ's are messed up between the decks. Sometimes it works flowless but sometimes all CDJ's controls the same (active) VDJ Deck. All CDJ's have a different ID from 1 to 4 controlled by network setup of Pioneer's ProDJ Link. Same problem happened when manually sets the player ID. The CDJ's Eject button switched the (active) deck but again all CDJ's responses to the same (acttive) VDJ Deck. 2 Deck configuration with 2 CDJ2000's gives the same problem. Please make it possible to control dedicated VDJ Deck selected by Player ID in CDJ Setup if possible.
geposted Mon 17 Jan 11 @ 11:51 am
