Yes, I know I'm probably the most stupid user ever, but I'm totally new to this software and cannot find this (probably really simple) answer anywhere: I just can't figure out how to preview a mix of two songs for, lets say 10 seconds before and after the mixing. It can't be that I need to save my whole mix before I can listen to it with the possibility that it's 'crap'... So, please, don't laugh at my ignorance. I need help, pleeease. (And - no, I'm not a DJ, I just do this for fun).
geposted Tue 18 Jan 11 @ 4:09 pm
To be able to pre-listen to music using headphones, you will either need two sound cards or a sound card with multiple outputs, such as a 5.1 surround sound card or preferably a dedicated DJ sound card (E.g: Numark DJIO or Native Instruments Audio 2 DJ.)
With a laptop, you can add a USB stick sound card that will provide you with the additional output that you need.
Alternatively, you can use a single sound card and the mono split option in VirtualDJ's sound setup, however this will only give you MONO sound. You will need a splitter cable to split the left/right channels - Please search Google for: 3.5 jack splitter to mono
Once you have suitable sound card(s), you will then need to go into VirtualDJ CONFIG -> Sound Settings and choose Outputs: Headphones and select the appropriate sound card(s).
NOTE: In Home FREE, sound card options are limited. To be able to headphone pre-listen, you will either need a 5.1 card built into your computer, a basic external USB 'stick' sound card or use the MONO split option. For more advanced sound configuration, such as two separate cards or a multi-channel external DJ sound card, you will need to purchase either VirtualDJ Basic or VirtualDJ Professional: https://virtualdj.com/products/comparison.html
To choose which deck to pre-listen to, press the TAB key or click PFL button on the skin. Use the crossfader and/or volume sliders to control which deck is output live over the master outputs.
geposted Tue 18 Jan 11 @ 6:01 pm
