I've noticed with VDJ when loading in the tune from the one after and so on ive noticed the beats go slow kind of draggy and arent as bassy.
I also got these issues with Atomix and happens on every computer i go on.
It's really strange though.
If i play one tune on VDJ its fine and the next tune i play the beats just got a bit hollow they just go a bit slow and the tune doesnt sound as good.
Was just wondering if there's a way to solve this?
Hope you know what im talking about, cheers.
geposted Sat 16 Jul 05 @ 5:16 pm
I think it may be because you have Time Strech enabled, and it doesn't work very good, go to Config, then FAME and disable Time Strech
geposted Sat 16 Jul 05 @ 5:57 pm
That is exactly what it is.
MS
MS
geposted Sat 16 Jul 05 @ 6:07 pm
