Forum: Old versions
Topic: Default gain value. Can it be determined?
Is it possible to setup default gain value on both channels? Everytime I start VDJ I must decrease gain. Maybe I can setup somewhere in register a default value of the gain buttons?
geposted Thu 20 Jan 11 @ 3:58 pm
Sorry, this is not possible, unless you have a MIDI controller connected and VirtualDJ Pro https://virtualdj.com/buy/ , in which case you could map the action ONINIT to: deck left gain 40% & deck right gain 40% - This will cause the gain knob to be set to 40% on both left and right decks when the MIDI controller is initialised.
By default, the EQ's and gain will always start off at the 12 o'clock position, which is where most DJ's will want them initially.
Some MIDI controllers will send the positions of their knobs and sliders at start-up, so that the software matches.
Just simply add <init action="gain_volume 75%"> to my skin??? :D GREAT!!!
