How does the jog wheels work for you? Are they tuch sensative.. as stop when tuching the plate or do u need to actually move in a direction to stop it? other generall info would be great too how it works and such. How is it controlled .. is it midi or some emulation of a keybord or something like that? (in (for) v dj)
geposted Sun 24 Aug 03 @ 4:15 pm
deck is STOPPED: it works like a record. spin it forward and it sounds like you are similiar to using a mouse. Mouse scratches better than controller. I wish they would allow us to change sensitivity on controller jog wheels and map our own keys
No! they are plastic and have no way of doing that. they dont spin either. Like a normal DJ CD deck.
Yes You have to move it youself to go forward or back
Virtual DJ decided that they will support the DMC-1 (upgraded with special chip) or DAC-2 (with no modification) This is what GOT MY ATTENTION.
Virtual DJ supports...
Keyboard, mouse
standard midi controllers
DAC-2 (USB)*
Numark DMC-1 with upgrade chip (serial)*
Virtual DJ's controller (USB) http://www.virtualdj.com/features/hardware.html
* There will be a MIDI driver for the DMC-1 and hopefully for the DAC-2. watch this site. http://www.gizmolabs.net
WirelessDJ
"I don't take any DJ program seriously unless it has a rack mount controller"
Keyboard, mouse
DAC-2 (USB)*
WirelessDJ
geposted Sun 24 Aug 03 @ 4:26 pm
Virtual DJ set a basic support of DMC DAC controllers but remember that our controller will be touch-sensitive and will enable more features than DMC DAC can support currently.
geposted Sun 24 Aug 03 @ 4:32 pm
"or do u need to actually move in a direction to stop it?
Yes You have to move it youself to go forward or back "
Sorry my blunder i was a bit blurry well i meant was like if u put your finger on the jog does the record stop?... gueesing as it wasnt tuch sensetive that it dosent. (so if u wanted an slowdown you would actually have to press stop for those small stop/release,..)
">is it midi or some emulation of a keybord or something like that?
Virtual DJ supports... "
hehe would be nice to know in what way it does ;)
thnx for reply. wireless
geposted Sun 24 Aug 03 @ 5:19 pm
