We will see if there will be an answer from the team!!!!!!
geposted Sat 22 Sep 12 @ 10:59 am
zambari wrote :
+5 on midi clock output.
I know many people are happy with vdj as rewire master but I personally don't benefit from it at all (I route its signal through Ableton via soundflower and live needs access to the soundcard so it can't be a slave). It would be really sweet to sync !
+1
geposted Mon 24 Sep 12 @ 6:56 am
I have just tested MIDI clock on PC.
VDJ sends FA which is the sequence start for the timing clock, then F8 which are the actual clock messages, then FC which marks the end of the sequence, which is correct.
All I did to test this was to install LoopBe1, then used RTCS MIDI Sniffer to watch that port after selecting it in the registry tool.
geposted Mon 24 Sep 12 @ 12:18 pm
It does work on a PC. I've just confirmed MIDI sync from VDJ to:
A) an external device. I used an Akai MPC-1000
B) other software. I used Ableton Live. The MIDI was routed via LoopBe.
Windows 7 32 bit.
Windows 7 32 bit.
geposted Mon 24 Sep 12 @ 1:53 pm
Windows 7 32 bit.
Windows 7 32 bit.
Thank you both for confirming that it does indeed work for Windows users. The Macintosh user base still needs some love, however. Please help us, Atomix!
geposted Mon 24 Sep 12 @ 4:54 pm
so , im waiting to see what the final answer is to getting the entire thing to work as I had it working then over time the clock failed it was off mili sec but then grew over time. I would love to have something that has a direct link and a way so that I can see on the skin that the two are in sync like a two small led on the skin that blink so im not guessing and maybe a metro clock.
geposted Tue 25 Sep 12 @ 2:50 pm
An in-software LED icon indicating the master tempo clock for MIDI output (a MIDI "heartbeat") definitely sounds like a great idea!
geposted Tue 25 Sep 12 @ 5:37 pm
So Please tell my how ill setup VDJ 7.0.5 as Midi Master -> Traktor Pro with F1 Controller?
What cable should ill use?
Thx
pOpY
Thx
pOpY
geposted Fri 28 Sep 12 @ 9:16 am
Why would you need to use two DJ programs at the same time?
geposted Fri 28 Sep 12 @ 9:36 am
I want to use the F1 Controller from NI which comes with Traktor as a Sampler.
Traktor should be stay in sync with VDJ Tracks.
Thats the reason.
http://www.thomann.de/gb/mobile_prod.html?AR=279998
Cu
pOpY
Thats the reason.
Cu
pOpY
geposted Fri 28 Sep 12 @ 11:15 am
But you could just play the tracks in Traktor and use the F1....
geposted Fri 28 Sep 12 @ 11:25 am
nope, want to use VDJ ;) and sync to traktor, anybody tried this?
geposted Sat 29 Sep 12 @ 11:46 am
bump
geposted Wed 10 Oct 12 @ 10:40 am
What's the problem? Have you actually tried to sync VDJ & Traktor?
geposted Wed 10 Oct 12 @ 11:45 am
Yep. Please, Read the posts above.
Which hardware should ill use to sync vdj to traktor?
geposted Wed 10 Oct 12 @ 12:57 pm
You don't need any hardware.
geposted Wed 10 Oct 12 @ 2:45 pm
VDJ & Traktor are on different Notebooks! Could you please describe how ill set up the two programms to sync it together?
geposted Wed 10 Oct 12 @ 4:05 pm
Put them on the same computer and you can do it easily, without any hardware.
If you insist on making it hard for yourself, then you're going to need two MIDI interfaces - one for each computer.
geposted Wed 10 Oct 12 @ 4:49 pm
geposted Wed 10 Oct 12 @ 5:25 pm
Now that's cool!
geposted Thu 11 Oct 12 @ 2:53 am
