manage and burn cd thru vdj. most of the software out there don't record mixes properly you can hear the tracks change, even when you select no space between tracks.
geposted Mon 24 Jan 11 @ 11:02 am
Hi
When you want to burn your mix to a CD you have a choice of how to record it:
a. As a single track
b. As multiple tracks
Is sounds as if you have got as far as trying option b which I am guessing you have used VDJ to record to an audio file then used an audio editior to cut into individual tracks.
I had a post trying to find a way to get a pre-recorded mix to play correctly through VDJ without gaps - you will see from the post below the lack of success in doing this, however there is some advice and applications that do work for creating a mx in the way you seem to want.
http://www.virtualdj.com/forums/140839/PC_Version_Technical_Support/Using_Bought_Premade_Mix_CDs_MP3s.html
Hope this is of help.
Derek
Derek
geposted Mon 24 Jan 11 @ 2:38 pm
