Hi
I have seen that the Maya44 is recomended. What about other USB cards and specifically the AudioTrak EX7 - which looks to do what the Maya does and then some...could be a better allround purchase...?
Thanks
Thanks
geposted Sun 17 Jul 05 @ 5:43 pm
The maya 44 is recommended for TCVinyl users and TCCD users because it is a 4 by 4. Which means that it has 4 mono outputs for 2 stereo outputs, and 4 mono inputs for 2 stereo inputs, and it supports ASIO drivers.
geposted Sun 17 Jul 05 @ 5:55 pm
For TCV's, no. Can't see that EX7 has four (4) RCA inputs. Otherwise, it would certanly be OK.
geposted Sun 17 Jul 05 @ 5:56 pm
Okay I get it, the others are more along the lines of surround sound / dvd playback ...
What other cards are recomended? TO be fair ill probably go with the maya as its what i need for on the road but is there a combination card that would also handle features like the other AudioTrak cards have?
geposted Sun 17 Jul 05 @ 6:33 pm
Creatives Audigy 2 NX USB works aswell... the important thing is that the sound card has atleast 2 stereo outputs, to connect to a mixer for easier use.
geposted Sun 17 Jul 05 @ 7:10 pm
