Gemini - Ctrl-One
CONTROLLER DIGITALE SENZA SCHEDA AUDIO INTERNA PER CONTROLLARE QUALUNQUE TRACCIA AUDIO COME SE SI TRATTASSE DI UN DISCO IN VINILE O DI UN DISCO CD.
Gemini - Ctrl-Six
CONTROLLER DIGITALE CON SCHEDA AUDIO INTERNA A 2 CANALI STEREO LINE/PHONO - USCITA REC, MASTER E BOOTH - USCITA MASTER BILANCIATA - INGRESSO MICROFONICO - USCITA CUFFIA.
Caratteristiche comuni
LA SEZIONE PLAYER PREVEDE: JOG WHEEL TOUCH SENSITIVE + PITCH CONTROL CON PITCH BEND + TASTI PLAY/CUE/PAUSE + 3 TASTI HOT CUE + SAMPLER SELECTOR E SAMPLER VOLUME - LA SEZIONE MIXER PREVEDE: SLIDER + XFADER + TRACK FOLDER + ALTI, MEDI, BASSI E GAIN + LED METER.
IL CTRL ONE/SIX E` COMPLETAMENTE MAPPABILE, LAVORA CON I MAGGIORI SOFTWARE IN COMMERCIO E VIENE FORNITO GIA` CONFIGURATO PER IL SOFTWARE VIRTUAL DJ LE (IN DOTAZIONE)
Gemini - Ctrl-Six
http://www.geminidj.com/ctrl-one
http://www.geminidj.com/ctrl-six
geposted Wed 26 Jan 11 @ 2:18 pm
