Forum: VirtualDJ Skins
Topic: Skins virtual dj
Será que tem jeito de usar os skins do atomix no virtual dj??
Se alguém souber por favor me responda....
geposted Sun 24 Aug 03 @ 8:43 pm
Same answer as the Plugins!
atomix skins will NOT work with Virtual Dj
No matter how much you edit the XML it just doesn't seem to work. Not with Coffee or Jiffypop. LOL! ;)
yes actually if you edit the xml you can get them to work
just if you dont edit or make a new bmp it wont have all the Virtual DJ Features
@ DJ Walkers You got the Coffee and the Jiffypop to work by editing an old Atomixmp3 skin?!? The only thing I was able to get functioning correctly was the Guinness tap. lol! :)
yes i also have a "lady" dispenser working too :) lol
Muito obrigado...
no problem :)
