Sorry if this has been answered but I tried the search first.
How do I remove the "Virtual DJ" logo from my video screen?
Thanks
Thanks
geposted Tue 19 Jul 05 @ 7:00 pm
Upgrade to the latest version, and then there will be a "hide logo" checkbox in the video options.
geposted Tue 19 Jul 05 @ 7:28 pm
Welcome Rusty,
This is what you need.
https://virtualdj.com/nologopatch.html
geposted Tue 19 Jul 05 @ 8:17 pm
Thanks Rick, I am sure I will be tugging on your ear VERY soon for alot more info!!!!
geposted Tue 19 Jul 05 @ 10:14 pm
Call any time Russ, if you are using the dac 2 try the power user skin by cstoll.
The record case is huge and the font is just right, comes in 3 colors also.
Make sure you load up the DAC mapper in the plug in section.
Scour the forum for anything video related as far as set up goes, it's touch and go with laptops.
geposted Wed 20 Jul 05 @ 1:19 am
V-Mix Power Skin - https://virtualdj.com/addons/download.html?addon_id=1126
Hope you enjoy... and check out the new one by djjb, if you don't use video. It's really nice, would have loved that in the v2.x days.
cstoll
cstoll
geposted Wed 20 Jul 05 @ 1:45 am
Any way to get a white cursor Chris?
geposted Wed 20 Jul 05 @ 2:00 am
Not sure what you are asking? If you are talking about the Highlight bar then the that can be changed in the XML file in the 'browser' tag section. If you are talking about the 'blink' search cursor, it shows up white here?
cstoll
cstoll
geposted Wed 20 Jul 05 @ 5:01 pm
The cursor pointer is black and it gets lost on the black interface at times.
K?
K?
geposted Wed 20 Jul 05 @ 7:49 pm
