i put music genre in the comment section but each files has to be done seperately is there a way i can put blues in my commet section all at once this will be a big help instead of 15 diffrent times
geposted Wed 20 Jul 05 @ 4:54 am
You can use an ID3tag editor to write your comments and select the ID3 read option in VDJ.
Some of us write the genre in the filename.
Personnally I use subfolders.
geposted Wed 20 Jul 05 @ 6:07 am
Try out Flash Renamer, a nice ID3tag editor. Real powerful when you get the hand of it.
geposted Wed 20 Jul 05 @ 2:20 pm
Is there a tag editor that can copy automatically for multiple files the "genre" of EACH file into its "comment" field?
geposted Thu 11 Aug 05 @ 12:14 pm
Tag&Rename can do that, but the Comment field of the ID3 tag is not the same as the comment field used in VDJ.
geposted Thu 11 Aug 05 @ 8:19 pm
