Hi, when i load virtual dj (no playing any songs or video),
my SYSTEM process in task manager, immediatly goes to 20%..
When I load videos it runs around 60-80 %..HArdware acceleration make little difference.
Is this normal?
I have a HP dv4000 laptop.
1gb RAM
Intel Accelerator 900 w/128 mb RAM.
80 gb. drive.
pentium centrino 1.6 MHZ 2MB cache.
WIDE screen DISPLAY.
Is this normal?
1gb RAM
80 gb. drive.
geposted Wed 20 Jul 05 @ 6:40 pm
Considering the laptop is heavily under rated for running video. Then I am surprised you are getting any type of framerate.
geposted Wed 20 Jul 05 @ 8:19 pm
actually the frame rate is great. actually with hardware acc. the cpu levels around 20%
where are the video specs posted?
geposted Wed 20 Jul 05 @ 11:51 pm
The Systems may vary one from another depending in your hardware. Always you do something in Windows the CPU levels goes up and down. If you had a desktop with your posted issues, you got a problem, but with a notebook which runs with Pentium M is normal.
You have to change your energy controls in Windows. Use the "desktop or office" option instead of the "mobile" or "power safe" option.
Pentium M was made to run more time with batteries, that's why the cpu clock is in 1.6MHz, but it also change it's speed (down the speed) to safe power. If you have in the default mode the power controls (Energy Options in the Windows Control Panel) this could by your problem.
geposted Fri 22 Jul 05 @ 3:03 am
are the VIDEO recommendations anywhere?
I was thinking of returnign this laptop for a hp DV6000.
what do you think of this model
Operating System Microsoft(R) Windows(R) XP Home Edition with SP2
Processor AMD Athlon(TM) 64 3200+ (2.0GHz/512KB L2 Cache)
Display 15.4" WXGA BrightView Widescreen (1280x800)
Graphics Card 128MB ATI RADEON(R) XPRESS 200M w/Hypermemory(TM)
Memory 1.0GB DDR SDRAM (2x512MB)
Hard Drive 80 GB 5400 RPM Hard Drive
Primary CD/DVD Drive LightScribe 8x DVD+/-RW&CD-RW Combo w/Double Layer
Networking 54g(TM) 802.11b/g WLAN w/ 125HSM/SpeedBooster(TM)
Primary Battery 8 Cell Lithium Ion Battery
geposted Fri 22 Jul 05 @ 7:47 pm
Hey ACW, thanks for that tip !!.. with hardware acceleration and deskmode selected i am down < 10% cpu. framerate is great. too bad my video is still clipped w/hardware acceleration on..
geposted Fri 22 Jul 05 @ 8:43 pm
