Opos exei anaferthei ksana ta dyo ayta players/controllers kanoun APOSYNDESH ths kartas hxou tous otan gyrizoume apo usb/control mode se cd mode, me apotelesma to opio software einai syndemeno na crasarei, h na pagwnei. Eite einai to virtualdj eite to traktor.
Edo exoume kai mia episimi paradoxi apo ton Pulse (Pioneer Product Specialist):
http://forums.pioneerdj.com/eve/forums/a/tpc/f/582108656/m/4120090806
http://forums.pioneerdj.com/eve/forums/a/tpc/f/582108656/m/9300077116
"when you switch out of PC mode, the soundcard is naturally disabled so when you use the CD (or USB) output, the sound comes through the CDJ's outputs. It just so happens that Traktor doesn't take kindly to having a soundcard removed from use during operation and as a result, crashes."
"What you're asking it to do is not possible as it's not within the design of the unit to do so. Your only solution would be to use a separate soundcard for the Traktor output and use the CDJs as the controllers."
Me liga logia opoios thelei na exei sygxronws cd kai pc mode xoris problimata prepei na exei eksoteriki karta hxou.
*Kati pou isxyei kai gia ta Denon DN-3700, alla oxi gia ta Pioneer cdj-400/900/2000
Paidikes astheneies tha elega, ektos kai an o symbibasmos aytos meionei to kostos tou hardware kai ginetai syneidita.
geposted Sat 05 Feb 11 @ 1:02 pm
Πάντως τα CDJ-350 κυκλοφόρησαν μετά τα CDJ-400 οπότε δεν δικαιολογείτε ως "παιδική ασθένεια" κάτι που έχεις φτιάξει σωστά σε ένα μοντέλο να το χαλάς σε ένα άλλο...
geposted Sun 06 Feb 11 @ 9:21 am
Gia ayto akribos egrapsa 'ektos an....', allla...
Exeis kapoia eksigisi esy, na ginetai diladi gia meiosi kostous px kapoio tmima tou sound hardware na xrisimopoieitai apo to player se cd mode kai na prepei na aposyndethei apo to pc ?
H kapoia alli skopimotita marketing ?
geposted Sun 06 Feb 11 @ 11:45 am
Mallon to gnwsto kollhma twn apantaxou pioneerakhdwn..akoma kai sthn etairia...oti o dj prepei na paizei me cds gia na einai dj...h xafnikh strofh pros tis software lyseis..einai apla thema marketing gia na leme oti kaname kati kai se auto to komati...alla telika afou etsi ki alliws ta skasate gia na parete to mhxanhma paixte twra me cds pou einai kai o tropos pou sas epivaloume
geposted Sun 06 Feb 11 @ 11:56 am
Κατ' αρχήν ας ξεκαθαρίσουμε οτι δεν ξέρουμε την πολιτική της Pioneer. Για μια εταιρεία σαν την Pioneer η μετάβαση σε PC-Controllers κανονικά την βολεύει... ΠΟΛΥ μικρότερο κόστος κατασκευής και φυσικά επειδή ακριβώς είναι η "Pioneer" αμετάβλητες (σε σχέση με τα CDJ) τιμές πώλησης, πράγμα που απλά σημαίνει αύξηση του κέρδους της.
Απο εκεί και πέρα γιατί αποσυνδέεται η κάρτα στα CDJ-350 πχ δεν ξέρω αλλά υποθέτω οτι είναι θέμα hardware. Θα πρέπει το hardware να κρατάει ανοιχτή την επικοινωνία με το PC όταν παίζει CD (παρόλο που δεν στέλνει έξω τον ήχο) επομένως μάλλον ναι τίθεται ένα θέμα αύξησης κόστους, αλλά και πάλι μιλάμε για μια αύξηση της τάξης πόσο;;; 10-20 ευρώ ανα μονάδα;;; (και πολλά λέω)
Για μένα είναι απλά η απροθυμία της Pioneer να μπει δυναμικά στον χώρο τον controllers που την κάνει να βγάζει προϊόντα με τέτοιες σχεδιαστικές παραλήψεις ή αστοχίες.
geposted Sun 06 Feb 11 @ 2:38 pm
Ayto akribos kanoun ta cdj900. An exeis patisei to koumpi LINK pou ta bazei se pc mode (h link metaxy tous), me to pou tha patiseis to Power sto pc emfanizetai sto display "Pc Mode" "Push to connect". Den xreiazetai kan na fortosei leitourgiko to pc. An kai ta oi dyo pleyres (pc kai cdj) einai "stin mpriza" (kai on) kai syndeontai me usb kalodio exeis "link" Kai ayto mporei na einai "connect" h oxi, pantos to pc den xanei tin karta hxou, einai panta ekei ston device manager kai aplos kaneis connect apo to cdj ksana otan gyrnas apo cd. Einai ekpliktiko.
Endexomenos aytin tin eukolia pou mallon den stoixizei poly se kostos, theloun na tin poulisoun san xryso sta akriba tous montela apo cdj900 kai panw, twra pou katargisan to 400..
Etyxos omos yparxei o antagonismos pou tha to kanei me poly ligotera.
geposted Sun 06 Feb 11 @ 4:37 pm
http://pioneer.jp/support/download/dj-e/cdj-350/firm.html
εδω το firmware λεει οτι το λυνει το προβλημα!!!
geposted Fri 14 Oct 11 @ 7:25 am
