On the pdf setup doc for timecoded vinyl it says that you need at least a 3 channel mixer, why?
It seems that a lot of people are using 2 channel mixers. On the graph there is a connection described as channel 3 IN (samples) going to the laptop, why and what for? There is an Asio Driver for maya available, why should one use the asio4all driver? How long do the tcv last?
THX in advance!
THX in advance!
geposted Thu 21 Jul 05 @ 2:31 am
Thats for advanced setup of TCV, all that allows you to do is route the sampler signals to a thrid channel otherwise they will come out of which ever channel you specify.
if the original ASIO drivers work for your card use them. ASIO4ALL is only for cards that do not nativly support ASIO of the few cards which ASIO does not work with when utilising the original ASIO drivers
geposted Thu 21 Jul 05 @ 7:27 am
