Hi,
is there a slide show plugin that will auto rotate the images if wrong way round? ( landscape to protrait )
kind regards
Justin
kind regards
Justin
geposted Tue 08 Feb 11 @ 1:47 pm
Nope.
Mine sorts the scaling but won't auto-rotate. Surely there is no way of the plugin knowing if the actual content of the image would be correct before/after rotation?
geposted Tue 08 Feb 11 @ 4:17 pm
The reason I asked because I have seen it work on some of those picture frames you can get for your home. Look dead smart and thought it would be a great tool instead of going into each picture and doing it manually
geposted Wed 09 Feb 11 @ 12:58 pm
