How come the newer version of Virtual DJ PRO 7 Does not have the network tab inside of the options.
It use to be easy to setup two laptop on the same network of a router? does anyone know the newer version of virtual dj pro 7 that can connect to one system by syncing together?
I have tried syncing with my friends laptop but it goes out of beats on BPM 128.0 to 168.0 jumping like spike.
geposted Sat 12 Feb 11 @ 11:21 am
hello.... everyone,
am new to virtual dj pro7, i am wondering if anyone could help me in using it... i was trying to project the video to the tv but the whole thing is coming out in the tv including the virtual dj itself... i am using my laptop connect it via hdmi to the tv, i just wanted the video output to the tv and the virtual dj on my laptop... thanks
geposted Sun 13 Feb 11 @ 3:26 am
Please do not post the same message or question more than once.
Also, please do not hi-jack other topics that are not related to your question in any way.
Please open your own new topic:
https://virtualdj.com/forums/action/newtopic.html?forumid=20
geposted Sun 13 Feb 11 @ 1:34 pm
Hi, I just purchased vdj7 and I have it hooked up to my hercules rmx, and 2 stanton t.80's. When I hook one turntable up with everything it works fine. But when I go to hook both up Its like deck a controls deck B and the other deck does nothing. I think my problem may lie in the "config" at the top of my vdj screen but I have tried almost everything! Someone please help me!
geposted Mon 14 Feb 11 @ 10:47 am
As above, please open your own new topic on this subject rather than hi-jacking an unrelated topic.
Your question has absolutely nothing to do with network synchronisation.
geposted Mon 14 Feb 11 @ 1:27 pm
Dear Moderator
Fair call about thread hijacking but how about an answer for the original question??
Just saying.........
geposted Tue 19 Apr 11 @ 9:37 pm
In regards to the original question, the network synchronisation is depreciated and is no-longer available in VirtualDJ v7.
VirtualDJ v7 allows multiple decks (More than 2) to be used natively in the same instance, so there is no need for this feature any more.
If you are mixing alongside a friend on their own system, then you will need to use your ears to manually beatmatch your music to what they are mixing. Or if you connect multiple MIDI controllers, both of you could mix together on the same system thanks to the multi-deck support in VirtualDJ v7.
geposted Wed 20 Apr 11 @ 11:17 am
Or depending on how powerful your system you both can use 2 sets of decks or 2 different MIDI controllers. I'll post a video of how to do it later. I know there was a guy here on the forums who did the same thing.
Huey
Huey
geposted Wed 20 Apr 11 @ 11:22 am
Thanks I'll try searching up
geposted Thu 21 Apr 11 @ 8:28 am
