I was checking the memory usage in windows xp task manager and discovered that virtual dj version 3.0 was using 215 megs of memory. I have also discovered that the auto gain must be set to -2.8 or lower to get clean sound without distorting. Overall the program is great.
Please consider for your next update.
Thanks,
DJ Joe Kool Street Knowlege
Thanks,
geposted Sat 23 Jul 05 @ 4:42 pm
Do you have the Time Stretch disabled? Alot of the bass distortion comes from that.
MS
MS
geposted Mon 25 Jul 05 @ 4:16 am
If you have the limiter on, it compresses a little the sound.
Try disabling it to get better sound.
geposted Mon 25 Jul 05 @ 11:09 am
the memory 'hog' is due to vdj decompressing all audio into memory so that everything can be processed faster & is less reliant on the CPU. Ram is cheap these days and it is a small payoff for great preformance. recommend min 512mb and should have at least 1gb
geposted Mon 25 Jul 05 @ 1:10 pm
