Forum: Old versions
Topic: Hercules RMX Problem!!
i just got the hercules rmx from craigslist and it didnt have a cd.. the drivers from the website dont work . im using windows 7 64 bit
geposted Thu 17 Feb 11 @ 9:26 pm
If you don't have the original install CD, then you will need to purchase VirtualDJ Pro from https://virtualdj.com/buy/ to be able to use it. You can try it out in Home FREE for 10 minutes at a time before purchasing: https://virtualdj.com/download/free.html
You will need to upgrade your DJ Console drivers and firmware to the latest version. A link to download this can be found on the following page: https://virtualdj.com/wiki/Common_Device_Drivers.html
When installing, make sure that you follow the on-screen wizard instructions exactly. If any Windows 'found new hardware' prompts come up, please ignore them.
