- flippin double don't work the same as using a real turntable...
- need some scratch plugin that can sound the same as scratching a lp with the hand
- more echo plugins
- and something that works like the efx-1000
- more echo plugins
geposted Fri 18 Feb 11 @ 3:01 am
Sounds to me like you want to use timecode with real turntables then.
geposted Fri 18 Feb 11 @ 5:45 am
search by the web just put vst effects and done you gone find a lot of plugins and work more profesional like KJAERHUS AUDIO also mda products and Fruity Delay,Fruity Phaser From FL Studio
geposted Fri 18 Feb 11 @ 8:55 pm
+ 1000 on the efx 1000 effects, the only reason i still have mine is the ability to do a feedback loop
geposted Thu 10 Mar 11 @ 10:49 am
