I just finished my TRACE PAD 2.0 iPad remote skin.
While I have tested it in windows, I need to test it on an actual iPad.
I don\'t exactly own one so I was wondering if anyone who DOES own one would be so kind as to test it for me?
Just leave a comment here or something.
Here is a sample graphic:
geposted Sun 20 Feb 11 @ 4:05 pm
Your skins are all starting to look them same.........its not a bad thing if that's what your going for??
Huey
Huey
geposted Sun 20 Feb 11 @ 5:12 pm
It's a matched set lol "Trace Series" Desktop/Laptop iPhone & iPad.
So yeah, I guess they are supposed to look alike.
And TotalMixPro doesn't look like trace!
https://virtualdj.com/addons/12735/TotalMix_Pro.html
geposted Sun 20 Feb 11 @ 8:10 pm
I'll give it a test if you like mate!
Si
Si
geposted Mon 21 Feb 11 @ 9:58 am
While I have tested it in windows, ...
How did you do this? I mean can you try an iRemote iPad skin without having an iPad????
Did you divide the skin from pages to single smaller skins??
geposted Mon 21 Feb 11 @ 10:09 am
Nothing that fancy. Put a couple of "secret" pc buttons in (config, min, max) then coppied the bmp and XML to my skins directory and loaded it in VDJ
Granted the engine isn't the same but it gives me a feel for layout and text placement.
(also tells me if it's crashing or not)
geposted Mon 21 Feb 11 @ 10:17 am
Oh, and since re-reading your post DjDad I should also note that this is a single page skin as it seems all except for nanoscopic are thus far.
Makes it a lot easier to test without multiple pages.
DjChuck
DjChuck
geposted Mon 21 Feb 11 @ 11:38 am
I aim myself for testing the ipad skin...
geposted Mon 21 Feb 11 @ 5:12 pm
screen looks good colroful love to beta test this app
geposted Sat 12 Mar 11 @ 8:26 pm
Thanks, I'm currently re-designing the buttons but I will send you a link when I have the re-work complete.
geposted Mon 14 Mar 11 @ 12:46 pm
OK, the re-design is complete and uploaded for approval.
Cross your fingers. I got no feedback from the beta testers so... I\\\'m jumping in to the deep end!
LOL.
Here is the graphic
LOL.
Here is the graphic
geposted Wed 16 Mar 11 @ 3:01 pm
Can't load in my ipad, I've just got an error message
Looks great by the way.....
geposted Wed 16 Mar 11 @ 11:36 pm
I'm pretty sure that error was being caused because I still had the "pc" buttons on it when I sent it to you. I'll send you the latest version for testing.
geposted Thu 17 Mar 11 @ 10:23 am
Thanks, is there a way I can post LVL PRO with a mod's intervention?
geposted Wed 23 Mar 11 @ 12:34 pm
Now available for download... please leave comments or suggestions here.
Thanks
https://virtualdj.com/addons/12897/TRACEPAD_2_0.html
Thanks
geposted Wed 23 Mar 11 @ 12:35 pm
Tried both mac & win on different machines and the ipad (2) refuses to load the skin with a 'failed to load skin' error. Tell me if I can help with the testing. Thanks!
geposted Sat 21 May 11 @ 12:24 pm
Hi.
Does the i pad work withbluetooth?
since sometimes i don't have wireless connextion
geposted Sun 22 May 11 @ 7:51 am
No it does not. You need to setup an adhoc connection between your computer and your ipad.
geposted Sun 22 May 11 @ 11:58 am
I added the code iremote="yes" to the skin tag.
I hope that will fix it.
I can't troubleshoot myself because I don't have an iPad
geposted Sun 22 May 11 @ 5:30 pm
Love the skin. I've tried them all, and this is my favorite! One thing that's not functioning right is the browser. Nothing shows up in the window. I don't know if I'm doing something wrong, or if there's a glitch. Great work!! Hope you can work it out if it is a glitch.
geposted Wed 08 Jun 11 @ 12:15 pm
