...Navigate from the "Browser" window to the "Playlist" window, but also open subfolders in the "Browser" window in Virtual DJ using just the Track_Enter feature of Numark IDJ3 or any controller?
Please share any advice, I am new to this and I have all the drivers updated and everything else is working perfect. Thank you!
geposted Wed 23 Feb 11 @ 10:30 pm
Not sure but if it has the knob on it like the mixtrack that you turn to scroll through songs and stuff then u press it in to change it between the browser & playlist window. The same thing 2 open folders just click the knob while in the browser.
geposted Thu 24 Feb 11 @ 12:18 am
Thank you for the reply! It does have a knob that I use to scroll through songs and folders, but I think I must have it mapped wrong becuase after I press it, I can either only change between the browser and playlist window, or only open subfolders. Are you able to check your mapping settings and tell me what command you have for TRACK_ENTER?
geposted Thu 24 Feb 11 @ 10:43 am
Are you talking about to load the songs into the decks of VDJ? If so I have buttons on the mixtrack that says load Deck A or Load Deck B. But I will check just so I can give u the answer.
geposted Fri 25 Feb 11 @ 10:00 am
How do I record a mix using the numark mixdeck?
geposted Fri 25 Feb 11 @ 5:41 pm
The mixer part of the MixDeck is a real hardware mixer - Please see https://virtualdj.com/homepage/jpboggis/blogs/4135/Recording_your_set_or_broadcasting_when_using_an_external_DJ_mixer.html
geposted Sat 26 Feb 11 @ 1:52 pm
how do i configure my timecode vinyl in VDJ using my VMS4
geposted Sat 26 Feb 11 @ 3:18 pm
Does anyone know how to make the browser window go back? I know if you push the browser knob, it will open the folder and allow you to scroll thru the contents of that folder. I would like to figure out how to map it to make it go back one folder at a time. I am using the IDJ3 with Pro.
geposted Wed 20 Apr 11 @ 3:12 pm
