Hi everyone,
I'm wondering if there's a way to configure the "beat" parameter on the Echo Doppler effect without using the laptop. More specifically, I've assigned a button to activate the effect but it would be extra handy to have that same button sync the effect to the beat.
Right now wht I have to do is go into the effects tab, click on "Echo Doppler" then click on "Beat".
Thanks.
Thanks.
geposted Sun 27 Feb 11 @ 8:21 pm
You can use a VDJscript command such as:
to choose the beat synch to a full beat from any of your keyboards or controllers, when you activate or deactivate it.
effect "EchoDoppler" active & effect button 2
geposted Mon 28 Feb 11 @ 6:23 am
Will absolutely try that!
Just wondering because I'm learning programming (c++, c#), how does it know which parameter, beat or 1/2 beat?
geposted Mon 28 Feb 11 @ 8:51 am
That isn't a matter of C++/C# (and, they need YEARS to be mastered by newbies), just change the button number in the VDJscript string :D
geposted Mon 28 Feb 11 @ 12:28 pm
So Tex, that will work for any plugin that has buttons?? If so that's great!!
Thanks for the time and info
Huey
Huey
geposted Mon 28 Feb 11 @ 12:51 pm
Yup, unless the plugin has it's own GUI.
geposted Mon 28 Feb 11 @ 1:22 pm
GUI, that's the window that pops out like with some vst's right?? If so ok I got it!
Huey
Huey
geposted Mon 28 Feb 11 @ 1:39 pm
Yup, and some embedded GUIs like ScrollText and Text2D.
It is possible for plugin developers to implement the button control still with a custom GUI, but not all do.
geposted Mon 28 Feb 11 @ 2:00 pm
Right on!!
Thanks for the info
Huey
Thanks for the info
Huey
geposted Mon 28 Feb 11 @ 2:23 pm
It worked! Only Thing that was a bit confusing is that the sliders don't move to reflect the beat/half beat as they do with the mouse but it's no big deal.
geposted Wed 02 Mar 11 @ 8:25 am
I know, but that effect has been made for manual echo length changes, and with a non-linear slider it is much easier to "warp" the sound by hand, and sounds much better ;-)
geposted Wed 02 Mar 11 @ 9:58 am
You, my friend, are a genius.
geposted Mon 07 Mar 11 @ 4:21 pm
download link some echo doppler ?? it is urgent
pd: sorry mistranslation use google xq not speak English
geposted Wed 10 Aug 16 @ 2:08 am
For licenced users only. Sorry
Sólo para usuarios con licencia , lo siento.
geposted Wed 10 Aug 16 @ 2:24 am
how can I download thi effect
geposted Tue 22 Nov 16 @ 11:03 am
geposted Tue 22 Nov 16 @ 11:04 am
