Is there any way of getting rip vinyl to encode as a wav file?
Thanks,
Derek.
Thanks,
Derek.
geposted Mon 25 Jul 05 @ 5:17 pm
I'm not sure it's possible.
geposted Mon 25 Jul 05 @ 5:19 pm
It is easy,I have done it with a few of mine. Just get a sound recorder, I user nero sound recorder, plug your mixer into your pc as though you were going to record a set,then hit record, play your tune, leave a silence for 5secs then play another, and the same again. When you have finished your left with a big wav file, if you now cut it into the seperate songs and save them as mp3's ,job done. Just done a search on download.com and there are loads of progs on there that do it automatically for you,take a look.
http://www.download.com/3120-20_4-0.html?qt=record+vinyl&tg=dl-20&search.x=0&search.y=0&search=+Go%21
geposted Thu 28 Jul 05 @ 12:15 am
