Hey. I'm running the demo version of VDJ and I seem to be getting the problem that when I speed or slow songs by more than a few tenths of a % they start to sound metallic and nasty, and there is a kind of flange effect on the bass hits. Any reason for this, or solution?
Thanks.
Thanks.
geposted Tue 26 Jul 05 @ 3:44 pm
disable the TIMESTRETCH in the settings
also i reccomend you to disable autogain
and on some songs adjust the gain of the deck to something lower in order to avoid distrotion
the effect like the beat is not exactly on time is caused by timestretch anyway ...
geposted Tue 26 Jul 05 @ 4:18 pm
Ahh cheers that sorted out the problem. Thanks alot!
geposted Tue 26 Jul 05 @ 5:20 pm
