Forum: Old versions
Topic: I messed up my VDJ
Hi I clicked in VDJ theres 3 buttons on the top right the minimize thingy, the maximize thingy and the close button. well I clicked on the maximize thingy and now it does not want to go in. please help.
geposted Sat 05 Mar 11 @ 10:01 am
Rightclick, on the Windows VirtualDJ icon (Taskbar) and close VirtualDJ. Then restart the application. A window will probably appear notifying you that the skin resolution is larger than your native. Click Cancel and it will load the default skin.
Choose a skin similar to your native resolution or smaller, and you will not have such issues anymore.
Having the same problem, I got this program legally with my numark mixtrack pro. I clicked maximize and now cannot get to the icon to minimize my screen. Tried removing the skin files from the folder with no luck. This is really really frustrating, now I can't even use this program I got today...... Please any help like hotkeys or something would be great. Oh yeah tried reinstalling with same issue.......
oh djdad: window does not appear asking if I want to change resolution, I'm at a loss....
Uninstall and Re install the software
If that doesnt work, run regedit (Registry Editor) and locate HKEY_CURRENT_USER \Software\VirtualDJ and change the Maximized registry to 1
did that, updated. still same problem
"Installed LE today, clicked maximize, now I can't get to the minimize button on the top right because it's zoomed in way too far. tried putting different skins in folder, tried changing resolution, tried reloading software like a hundred times, tried reinstalling, tried updating to latest version, don't know what else to do. BOUGHT LEGALLY so I shouldn't have a problem in theory. Please please please help I am really anxious to play with my new toy. shouldn't matter but I'm running windows 7 in 1920x1200 mode normally, I can give more detailed specs if it helps."
see my edit
thank you!!!! worked great only I had to change maximize value to 0.
what if my regedit doesn't have the file? even after reinstalling?? or how do I find my skins? or resize?
Try download the home free version https://virtualdj.com/download/
Hopefully this will fix your issue.
Also please don't post in threads more than 1 year old. The information is often out of date.
If you still have an issue please feel free to open a new post or contact support. https://virtualdj.com/contact/
[CLOSED]
