I have an Audigy 2 Platinum, is it possible for me to preview a song in my headphones while another track is playing?
thanks
Dimava
thanks
Dimava
geposted Tue 26 Aug 03 @ 11:56 am
Yes it is... if you buy the full version :)
This is not possible with Demo version.
geposted Tue 26 Aug 03 @ 12:01 pm
ok, great but how does the software know what channel goes to the headphones in the front drive, and not mix it with the rest of the sound?
geposted Tue 26 Aug 03 @ 12:33 pm
You have to set the audio configuration (not available in demo version).
With 3D sound card or 2 sound card you will have 2 possibilities:
- one output for mixed sound and one for headphones
- one output for each deck.(for external mixer)
These 2 settings are available with one sound card but the stereo output is split into 2 mono outputs.
If you choose the mixed and headphones setting, headphones
will receive the sound of the active deck (level at 100% even if the crossfader or the volume slider mute/reduce its level for the mixed output).
geposted Tue 26 Aug 03 @ 12:51 pm
i have 2 sound card 1 platinum audigi + 4.1 sound blaster they are both creative can i use them both or its better if creative+yamaha sound card...any advise please
geposted Wed 27 Aug 03 @ 1:23 pm
Well, I have an audigy sound card, I was wondering how to preview something in deck 2 while I am still playing a track in deck 1, as soon as I am done with deck one ill have to start the preview I listened to in deck 2. So how does that work exactly I tried the sound configuration but still didnt get to a conclusion, so it would be greatfull if I get some tips on how to work this out. Id like to preview deck 2 in my headphone, while playing both or just deck one in the normal 5.1 speakers.
geposted Sun 07 Dec 03 @ 7:22 pm
You can't do that with the trial version!
geposted Sun 07 Dec 03 @ 11:48 pm
Well yes I do, but I asked due to something I need to know I didnt tell I am a trial or a full, I just need to know.
geposted Mon 08 Dec 03 @ 12:52 am
If you don't mind mate.
geposted Mon 08 Dec 03 @ 12:53 am
from that it sounds like you have a cracked version!?!?!?
geposted Mon 08 Dec 03 @ 1:05 am
Wish I really did, but I am willing to buy one shortly, and why are u so angry while telling me ?
geposted Mon 08 Dec 03 @ 2:27 am
i dont see anyone being angry? i just asked a question!
geposted Mon 08 Dec 03 @ 7:36 pm
