Peace All.
I Just Recantly Bought a VCI-300 And For SOme Reason Im Haveing A Big Problem With Getting It To Work With Virtual DJ 7 workes Percect With Itch but i bought VDJ for the extras and so far its looking like i waisted my money : ( i been useing VDJ for years now i got a hercules RMX that i use to for time code but as if right now i just want to be able to use my new VCI 300 with my VDJ 7 if ne one can help i would be reallly great full thanks in advance PEACE
Its Giveing Me A Sound Card Error I Have WIndows 7 as well......
geposted Thu 10 Mar 11 @ 10:08 am
hey bro. Did you ever find out an answer to your problem. I have to spin at a club and i use a vci 300 and itch. they use a mac and vd7. i need to know if my vci will work with it and if so what do i need to do.
geposted Thu 14 Apr 11 @ 12:14 am
The VCI-300 was not intended for use with any other software apart from Itch, so unfortunately it does not have proper ASIO drivers available.
However, you can use ASIO4ALL to get around this problem - Please see https://virtualdj.com/homepage/cioce/blogs/3832/_ENG__Vestax_VCI-300_Typhoon_Spin_audio_setup_on_Virtual_DJ_6.html
The VCI-300 is natively supported as a MIDI controller in the latest VirtualDJ v7.0.3 Pro: https://virtualdj.com/buy/
geposted Thu 14 Apr 11 @ 4:01 am
