With this new OGG sample format, most of the time when you load a sample on the deck it does not match the BPM that the sample had at the time it was made. This causes headaches if you want to edit or play your samples on decks.
However this did not happened before the sample format was changed to OGG. You could drop a sample on the decks and loop it on the fly and it was perfect all the time, now they are useless for that purpose.
This should be looked at.
Thanks
Thanks
geposted Thu 28 Jul 05 @ 5:58 am
