Hi
How do i link a button on the DAC-2 to a specific function on Virtual DJ ? Example if i wanna use the DAC-2 "FX" button to crossfade the videos.
Thanks
Dj Flame
Thanks
Dj Flame
geposted Thu 28 Jul 05 @ 6:35 pm
I think you must use the Dac-2 mapper,
you will find it on this page: https://virtualdj.com/addons/view.html?type=effect%20plug-in&page=2
geposted Sun 07 Aug 05 @ 5:43 pm
The DAC-2 mapper is a hard coded DLL. A customizable mapper does not exist for the DAC-2. If you want that type of functionality you need to look into creating some keyboard shortcuts. Or, write a new DAC mapper from scratch. You can find information about writing plug-ins from the 'Download' section in sub-section 'Effect Plug-in Section'
geposted Sun 07 Aug 05 @ 7:26 pm
That DLL is buggy. Turn the outer jog wheel all the way to the end of a track and the track will run into an endless accelerated loop with no way of stopping it. Only way out is to exit VDJ.
There's a MIDI driver for Dac-2 by Gizmolabs that allows you to reprogram all the buttons (actually not sure you can reprogram the jog wheels and/or pitch faders) on the Dac-2 to any function in VDJ but I didn't invest in it, just used the trial... I'll have to look more into it.
geposted Thu 11 Aug 05 @ 7:06 pm
