I purchased Virtual DJ Full Pro version 7.0. I entered the license key in my profile but when I try to download any video transitions it says software need to be installed first. I notice these transitions say they are for version 4.0. Can you use them with 7.0? and if so why can I not install them. If they are not compatible are there any or will there be any added for 7.0? Any help is greatly appreciated.
geposted Tue 15 Mar 11 @ 8:54 pm
Please post just the links of the plugins that cannot be installed in this thread ..
http://www.virtualdj.com/forums/144671/General_Discussion/Skins__Effects__etc__saying_VirtualDJ_is_not_installed.html
Read more infos here..
http://www.virtualdj.com/forums/144259/General_Discussion/_NEW__VirtualDJ_7_0_3_released.html?page=3
geposted Tue 15 Mar 11 @ 9:51 pm
Question about this link: When you speak of username below you are talking about our Vitual DJ Username? I want to be sure I do this correctly and not screw up my registry so any details for correcting this issue is greatly appreciated. Let me know, thanks!
Ok, actually found the issue ... the old installers we used is looking for a specific registry key for the Home Folder of VirtualDJ.
Temporary fix -
Edit the Registry -
Add a new Key in the -> HKEY_LOCAL_MACHINE\SOFTWARE location -- just right-click on the SOFTWARE entry and choose New -> Key
Give it the name of VirtualDJ
Add a new String value in the VirtualDJ Key -> right-click on the VirtualDJ entry and choose New -> String value
Give it the name of HomeFolder << very important 'no spaces'
Double click on the new string value entry and put the path to the home folder location. Recommend you browse to the location in a folder window and copy/paste the path from when you are viewing the VirtualDJ folder contents.
By default this would be -- C:\Users\{Username}\Documents\VirtualDJ
The {Username} is to be replaced with what ever your user account name is.
Temporary fix -
Edit the Registry -
geposted Fri 18 Mar 11 @ 9:55 am
I did whay you requested with the registry editor and still cannot install. I get the same error software not installed. Here is what I am trying to install.
http://www.virtualdj.com/addons/2263/Spiral.html
Let me know what you think.
geposted Fri 18 Mar 11 @ 3:19 pm
Make sure you do all the steps as described. It worked for me. The above plugin iis installing normally.
geposted Fri 18 Mar 11 @ 6:58 pm
Did the exact same thing as noted in this message. Can you install something for version 4.0 into version 7. I have installed other skins and effect that are associated to 7.0 with no problem.
geposted Sat 19 Mar 11 @ 10:33 am
