hey DJDAD,
can you make this skin for my mac in 1280 X 800 ???
thx Dj D-RoCk
thx Dj D-RoCk
geposted Wed 11 Jan 12 @ 9:12 am
Djdrock wrote :
hey DJDAD,
thx Dj D-RoCk
thx Dj D-RoCk
Hello
Have a look on this tool:
https://virtualdj.com/addons/7187/Skin_Resizer_Tool.html
Greets
geposted Wed 11 Jan 12 @ 12:57 pm
I have an issue with GROM: the VU meter with shows the level only shows the level when the crossfader is in the middle or on the side of the deck ... thats not so cool when pre listening. is there a possibility to change that?
Oliver
Oliver
geposted Mon 23 Apr 12 @ 9:52 am
thanks for everything
geposted Wed 28 Nov 12 @ 5:44 am
been using GROM for a month or so now...
It's the first skin that has lasted that long. I'm normally back to MixLab within a week or so.
That said, on Saturday I have a gig with video and karaoke so had to switch back.
Pretty certain I haven't missed anything and that GROM doesn't support video right now. But just in case I have I wanted to check.
And to ask how difficult it would be to add video...
Only need deck/preview screens, not an output. And the ability to map my MC6000 "video" button to turn them on/off.
Cheers,
Roy
Cheers,
Roy
geposted Tue 29 Oct 13 @ 12:59 pm
Hi DJDAD,
I really like the 2 Deck-Version of your GROM-Skin very much.
As I just switched from a two-Deck controller to a four-deck controller I would still like to use it but with four decks.
I found your four deck version but it is a little bit overloaded for me.
Do you think there is a possibility to add just two smaller player-sections below the Original two decks?
Best regards,
Joerg
Best regards,
Joerg
geposted Sun 05 Jan 14 @ 7:48 am
Even though free time is very limited lately, i still cant find any easy way to do what you asked. The 4 deck skin has almost the same features as the 2 deck one, so adding 2 more decks in the 2 deck version, right below the existing one, it wouldnt save more browser.
I suppose you mean 2 additional mini-decks (with less info than the top/main ones). Not a bad idea, but not much time currently. Sorry.
geposted Sun 05 Jan 14 @ 1:24 pm
Yes, you are right with your guess.
Additional mini-decks would be perfekt - but as you do not have time at the moment - maybe you can put it on a list for later enhancements. ;-)
Maybe I'll find some time do try some first things but at the moment I'm also very short of time. 😞
Cheers,
Joerg
Cheers,
Joerg
geposted Sun 05 Jan 14 @ 5:07 pm
please 1 for v8
loved it
greate job
thank you
loved it
greate job
thank you
geposted Thu 22 May 14 @ 6:03 am
