Just wondered whether it's possible to remove any of the effects on Sonique? and also whether it's possible to add any others?
geposted Sat 19 Mar 11 @ 9:26 am
Yup, just delete the corresponding SVP file mate, that simple. Adding new ones consists of copying it into the folder with the others.
If you're adding a new one test it thoroughly - some misbehave!
geposted Sat 19 Mar 11 @ 9:44 am
Thanks Scott.
Do you know where can I get new effects for it?
geposted Sat 19 Mar 11 @ 9:56 am
Unfortunately not really. There are a few out there - older versions of GeForce included an SVP version for example. It really is a dead format though and has been for a long time.
I've written a MilkDrop plugin but I can't release it until I'm 100% happy with it as it occasionally hangs my gig system.
geposted Sat 19 Mar 11 @ 1:37 pm
Go to my blog on my home page mate and you will find a download link including the g-force converted to a sonique svp just copy into the sonique folder.instructions in the blog...
geposted Sun 20 Mar 11 @ 6:08 am
