Hi All
This is my first post so apologies if Ive posted this in the wrong section......
I use Virtual at my residency and I am trying to get a few plug ins/samples etc, but they all seem to be 'professional' only and its says im home edition. Is there anyway around this ? (I purchased it rather than downloading it from this site)
secondly If I wanted to put a mix out for people to listen to can I do this on here or more importantly is it allowed
With Thanks In Advance
Urban Gorilla
Urban Gorilla
geposted Fri 29 Jul 05 @ 1:14 pm
You Buy DJ MixStation2, and VirtualDJ is an upgrade for you. You didn't purchase VDJ, the only way to get VDJ is in this site.
With VDJ you can broadcast your mixes. You find more information in the software forum. (Use the find topic option to locate what you want to search).
geposted Fri 29 Jul 05 @ 2:41 pm
Thanks....
Yes I do have Mixstation 2, so is this different to virtual dj ? I was under the impression that it was the same thing. I know that looking at the picture on the download section it looks exactly the same as that one.
I think looking at my profile I havnt loaded my reg. no. does that have anything to do with it ?
Thanks for your patience..
Urban G
Urban G
geposted Fri 29 Jul 05 @ 5:02 pm
