Is it possible to convert the audio signal to be compatible with the Phono in of the mixer.
Like this , we can plug virtualDJ in the Phono and an CD Player in the Line on an mixer. It is an Inverse RIAA ????
and in the sound config/advence/
the textBox are too small , we cant read correctly the sound card name if we have more than one. Is it possible to have bigger textbox , or at lease put tiptool
geposted Fri 29 Jul 05 @ 11:25 pm
Good idea to have an inverted RIAA amplification.
geposted Sat 30 Jul 05 @ 3:40 am
Okay guys after few hours of maths and testing I uploaded my first FFT plugin "Inverse RIAA".
I just has to be reviewed and hope it will serve you all :-).
Thanks for a good idea.
I tested it with hercules dj console plugged to NUMARK DXM-01 USB to phono and compared
it with the line in sound. I think there's a little difference but not very audible and can be because
of NUMARK implementation. Testing on other mixers is welcome.
Please report back any troubles, ideas....
geposted Mon 08 Aug 05 @ 2:45 am
WOW , i want to test it
where is it ???
can you me by mail (in my blog)
where is it ???
geposted Mon 08 Aug 05 @ 6:17 am
Wake up NEO, ...ehm Benjamin,
follow the hotmail inbox. :-)
geposted Mon 08 Aug 05 @ 8:58 am
yess , it was in undesired folder ?!
the plug-in make VDJ skip every seconde
geposted Mon 08 Aug 05 @ 5:02 pm
as I looked at your PC specs it's weird. Anyway I'll test it again right now i'm sitting at work wil test on my work pc too. it's 2.6 p4 1gig ram
whoa, you are right, it's bad
anyway i downloaded again the exact version I sent you again to my notebook and there it works smoothly.
It's only 1.5 Centrino with 768 ram.
It's because of some initialization, i will be overtime at work and compile and debug on this pc.
Hope I'll solve it soon.
geposted Mon 08 Aug 05 @ 7:46 pm
looks like it's working now. I was at work till 22:00 and we had automatic alarm set at about that time.
When i was closing door at my office the alarm started to beep that it's about to turn on.
It was veery close :-)
mud-v, have I to resent you the fixed version or you have access to the download area's unactivated plugins?
geposted Tue 09 Aug 05 @ 11:45 am
i don't have access to the download area's unactivated plugins?
geposted Tue 09 Aug 05 @ 8:33 pm
ok, look into you inbox :-)
geposted Tue 09 Aug 05 @ 8:49 pm
Cool idea, but I really have to warn you.. It is not good idea to put line out to phono in. Even if this works, I'd be careful since if for some reason the signal gets too strong (accident with volume control or plugin setup) it may be goodbye to your phono-in at the least - in worst case your loudspeakers etc too!
geposted Fri 12 Aug 05 @ 1:13 am
That's why i recommended to lower the gain on mixer and also lower the output of vdj .. it the upload text. Anyway it's a good to passivly reduce the output signal by resistor in order to gain better Signal/noise ratio.
Look into my BLOG for schematics :-)
geposted Fri 12 Aug 05 @ 11:30 am
