I have a HP nx9010 notebook, 3.06ghz (1.60ghz) true intel mobile CPU, 256 Mb ram, and ATI 345M GPU.
When a music video is loaded in each player it start lag and stutter. What more do i need to fix it? more ram or faster HDD (external).
Thanks
Flame
Thanks
Flame
geposted Sat 30 Jul 05 @ 8:49 am
Both. The RAM most be 512 at last, but I recomend 1GB. The HD you could change your internal disc if you want (to a 5400 or 7200 RPM HD). An extrenal HD is the option to store your music and videos. It must be USB 2.0 (because, I think nx9010 don't have a firewire input) 160GB or greater.
First go for more RAM.
geposted Sat 30 Jul 05 @ 9:21 am
ok, ill go buy a 256 more quick then i have 512
geposted Sat 30 Jul 05 @ 10:04 am
I'm pretty sure 512Mb will solve your issue.
geposted Sat 30 Jul 05 @ 12:11 pm
Pay attention if you don't have 2x128Mb in your notebook ...
If it's the case you'll have to buy 2*256 or 2*512
geposted Sat 30 Jul 05 @ 3:46 pm
True, good thinking clax :)
Also, even though generic is much cheaper, I'd still go for a brand name (Corsair, Samsung, Infineon,...), after checking on the memory manufacturer site that the RAM you'll buy is compatible with your notebook.
It's disappointing to insert the new RAM and see that your computer won't boot up, and notebooks are famous for that...
geposted Sat 30 Jul 05 @ 6:08 pm
DJ Flame: Their right, RAM is what you need..
geposted Sat 30 Jul 05 @ 8:10 pm
thx, ppl. I went to shop and no one in our town had ram for me, ill have to order online,
geposted Sat 30 Jul 05 @ 11:41 pm
Its not the ram update to 3.1 and disable Video hardware acceleration. The studder will go away.
geposted Mon 08 Aug 05 @ 3:15 pm
Hmm.. Still, for the whole, more RAM is preferred. I'd go with atleast 512. You can compensate by increasing the virtual RAM, but hardware memory is better.
geposted Mon 08 Aug 05 @ 4:04 pm
You will need 512 mb's of ram to run VDJ. I was partly wrong I didn't notice the amount of ram you were using.
geposted Tue 09 Aug 05 @ 2:57 am
