I have a 7.1 soundcard, (soundblaster), i wanna know how is it possible to use the headphones for previewing the song and the main output going to my 7.1 speaker system? How do i set this in vdj? and how do i connect my speakers and phones?
Thanks in advance!
Thanks in advance!
geposted Sat 30 Jul 05 @ 9:31 am
To use your headphones to preview the song you most use the 7.1 config, so you can't connect 7.1 system with headphones for previewing the song with only one sound card(or only your SB). But you can use another card (the one in the motherboard for example) to do the preview.
To configure 7.1 in your SB, you must use speaker configuration in the installed software of the SB.
regards,
regards,
geposted Sat 30 Jul 05 @ 9:46 am
