so far there is only myself and one other person i know with this problem.
I spent hours setting up my samples just for them to totally reset themselves when i shut the program down. So now im having to set them up again every time i load the program. Is this normal and is anyone else having the same problem. What can i do about this.
Apart from that one problem i find virtualDJ to be the best program ive ever used and have already told people about it in hope that they will use it too.
Its the bomb, and i use it every day. The girlfriends always moaning about it, says i pay more attention to the computer than i do to her. But she cant mix music for me!
Anyway, A BIG THANX TO THE TEAM OF VIRTUAL DJ FOR A JOB WELL DONE.
DJ RickyBoy.
DJ RickyBoy.
geposted Sat 30 Jul 05 @ 1:52 pm
Best thing to do then is to buy the software and that way you can benefit from all the plug-in's available. One is the "Sampler manager" that will let you set and save your samples as you want in different banks. This should solve your problem.
geposted Sat 30 Jul 05 @ 2:51 pm
dj rickyboy, the thing is that with cracked versions of VDJ is that the samples don't work correctly.
If you like the software that much then buy it!
geposted Sun 31 Jul 05 @ 12:10 am
