Hello,
When installing VDJ (on 2K or XP computers) over an old version (update) the default directory suggested by the wise
installer is "C:\Program Files\VIRTUA~2" instead of
"C:\Program Files\VirtualDJ". You have to change it manually
if you want to install in the right place.
DJ LARIOS
DJ LARIOS
geposted Tue 26 Aug 03 @ 11:26 pm
I got the same problem
geposted Fri 29 Aug 03 @ 11:07 am
just hit OK... it's still installing to the proper directory.
At least it does for me.
geposted Fri 29 Aug 03 @ 4:39 pm
It doesn't for me. It really create a new directory
called C:Program FilesVIRTUA~2.
DJ LARIOS
DJ LARIOS
geposted Sat 30 Aug 03 @ 11:23 am
It doesn't for me too.
I found a way to fix this issue.
Run regedit
Delete the folder:
HKEY_LOCAL_MACHINE
- SOFTWARE
- - VirtualDJ
And reinstall VDJ
Run regedit
Delete the folder:
HKEY_LOCAL_MACHINE
- SOFTWARE
- - VirtualDJ
And reinstall VDJ
geposted Sat 30 Aug 03 @ 6:04 pm
Not corrected in V1.0.6 for me.
DJ LARIOS
DJ LARIOS
geposted Sat 13 Sep 03 @ 4:44 pm
Just delete all virtual dj entries in the registry and then try install again..
Storm
Storm
geposted Tue 21 Oct 03 @ 12:11 pm
DJ Dark Storm,
Yes, there are several solutions to by-pass this problem.
The easiest is to type the right path in the installation
window ;-)
But the aim of this topic is just to report this little bug.
DJ LARIOS
window ;-)
DJ LARIOS
geposted Tue 21 Oct 03 @ 6:16 pm
Not corrected in V1_07B.
DJ LARIOS
DJ LARIOS
geposted Sat 15 Nov 03 @ 4:34 pm
Not corrected in V1_09.
DJ LARIOS
DJ LARIOS
geposted Sat 03 Apr 04 @ 5:32 pm
