VDJ does not recognise my new Vestax VCI-100 MK2 on my MacBook Pro, instead of the default VCI mapping it loads the default Vestax Typhoon mapping.
On my desktop PC (Win7) VDJ recognises the controller correctly...
I think that maybe the SysExID's of the VCI-100 MK2 and the Typhoon are both switched (or the same) in the default definitions of VDJ OSX.
Does anyone have a custom definition file for the VCI-100 MK2 that I can use or can I find the default definition file on my system and alter it?
tnx..
tnx..
geposted Thu 07 Apr 11 @ 8:54 am
This is because the VCI-100 MK2 is returning a SysEx ID that conflicts with that used by the Typhoon.
Originally this was not the case (It used a different SysEx ID that did not conflict.) The manufacturer may have made an error in their latest firmware. We will check with them to see if there is a solution.
On PC, this may not be a problem because USB VID/PID is used for identification in preference to SysEx ID (This is not possible on Mac.)
Unfortunately the definition cannot be user altered because it is embedded into the software. However, a custom definition with device name="VCI100MK2" should override it. We are not aware of any user-made definitions and mappers for this controller at this time (It is a new device.)
geposted Thu 07 Apr 11 @ 3:14 pm
OK...
I made a new definition file last night that works with the default mapper (my next gig is tonight and my previous controller died on me last weekend)
Not all the functions are in there yet (no leds) but I have basic control now...
I still have a problem mapping the high resolution part (14-bit) of the faders / jogs using CCMSB, i used the VCI-300MKII as a reference but it doesn't seem to work right.
geposted Fri 08 Apr 11 @ 4:23 am
How can i map VCI100mk2 to Virtual Dj ? can anyone pls help me ???
geposted Sat 09 Apr 11 @ 9:02 am
Use cc="number of LSB CC" ccmsb="number of MSB CC", e.g:
cc="0x02" ccmsb="0x01"
If it doesn't work right, swap the numbers for cc and ccmsb.
(When using miditrace or similar to monitor the MIDI signals from the VCI-100 MK2, you will find that each 14-bit one sends two different CC's (The MSB and LSB), which when combined produce the 14-bit value.)
geposted Sun 10 Apr 11 @ 1:41 pm
i have a Vestax VCI 300 mk 2, and it say's that Virtual DJ PRO natively supports this instrument. IT DOES NOT, i tried to connect, it does not work.
geposted Thu 15 Dec 11 @ 7:38 am
Most likely you are running an old out-of-date version of the software and/or you have not configured it correctly.
Please register your Pro serial number on the page https://virtualdj.com/users/edit.html and download the latest version from https://virtualdj.com/download/updates.html
Or if you have not purchased the software, please support it and its future development by purchasing it: https://virtualdj.com/buy/
You can try it out before purchasing in the latest Home FREE for 10 minutes at a time: https://virtualdj.com/download/free.html
See: https://virtualdj.com/wiki/VCI-300.html
geposted Thu 15 Dec 11 @ 8:34 am
Does the new ver of VDJ works with the to prods ......... (Mac + Vci 100 mk2)
I want to bay both and start with PCDjing.... but this post makes me worry ....
geposted Thu 15 Dec 11 @ 6:16 pm
i have same problem for vci 100 mk2 ...on mac ....any change ..?
geposted Tue 27 Dec 11 @ 12:03 pm
This may be because the SysEx ID of it has changed since when it was first released.
If you have access to a Windows PC, please use MIDItrace to query its SysEx ID and post it in this topic: https://virtualdj.com/download/miditrace.exe (Highlight the VCI-100 MK2 in both sections and click SEND.)
Also, check that the name shown in MacOS Audio MIDI Utility is set to the following (If not, rename it):
VCI-100MKII DJ-Controller
Another possibility is you are using an older version that does not support it. Please download the latest Home FREE from https://virtualdj.com/download/free.html and try with that.
NOTE: You will need to upgrade to the full VirtualDJ Pro to use other MIDI controllers besides the DMC-2 and TotalControl registered to your profile. You can upgrade at a considerable discount by going to: https://virtualdj.com/buy/
geposted Wed 28 Dec 11 @ 5:02 pm
I Have Now the Vci 100 mk 2 but still the same problem with the Home Ed
I run the miditrace ........
name VCI-100MKII DJ-Controller
send F0 7E 7F 06 01 F7
F0 7E 00 06 02 00 40 02 20 01 00 00 00 29 00 13 F7
B0 16 00 00
B0 17 00 00
B0 18 00 00
90 35 00 00
91 35 00 00
B0 16 00 00
B0 17 00 00
B0 18 00 00
90 34 7F 00
91 34 7F 00
B0 19 00 00
B1 17 00 00
B1 18 00 00
B1 19 00 00
B1 1A 00 00
B1 16 00 00
B1 26 00 00
B0 1C 00 00
B0 2C 00 00
B4 10 40 00
B4 20 00 00
B4 12 65 00
B1 1B 3E 00
B4 13 00 00
B0 1A 3C 00
B0 11 40 00
B4 14 64 00
B4 11 7F 00
B1 11 40 00
B1 21 00 00
B0 12 40 00
B0 13 40 00
B0 14 40 00
B1 14 40 00
B1 1C 40 00
B1 13 40 00
B1 12 40 00
B0 1B 40 00
B0 2B 00 00
B1 1C 40 00
B1 13 40 00
B1 12 40 00
B0 1B 40 00
B0 2B 00 00
B1 15 2E 00
B0 15 2F 00
B0 16 00 00
B0 17 00 00
B0 18 00 00
90 35 00 00
91 35 00 00
90 34 7F 00
91 34 7F 00
B0 16 00 00
B0 17 00 00
B0 18 00 00
B0 19 00 00
B1 17 00 00
B1 18 00 00
B1 19 00 00
B1 1A 00 00
B1 16 00 00
B1 26 00 00
B0 1C 00 00
B0 2C 00 00
B4 10 40 00
B4 20 00 00
B4 12 65 00
B1 1B 3E 00
B4 13 00 00
B0 1A 3C 00
B0 11 40 00
B4 14 64 00
B4 11 7F 00
B1 11 40 00
B1 21 00 00
B0 12 40 00
B0 13 40 00
B0 14 40 00
B1 14 40 00
B1 1C 40 00
B1 13 40 00
B1 12 40 00
B0 1B 40 00
B0 2B 00 00
B1 1C 40 00
B1 13 40 00
B1 12 40 00
B0 1B 40 00
B0 2B 00 00
B1 15 2E 00
B0 15 2F 00
I want to buy VDJ to but this problem stops me .....
B0 16 00 00
B0 17 00 00
B0 18 00 00
90 35 00 00
91 35 00 00
B0 16 00 00
B0 17 00 00
B0 18 00 00
90 34 7F 00
91 34 7F 00
B0 19 00 00
B1 17 00 00
B1 18 00 00
B1 19 00 00
B1 1A 00 00
B1 16 00 00
B1 26 00 00
B0 1C 00 00
B0 2C 00 00
B4 10 40 00
B4 20 00 00
B4 12 65 00
B1 1B 3E 00
B4 13 00 00
B0 1A 3C 00
B0 11 40 00
B4 14 64 00
B4 11 7F 00
B1 11 40 00
B1 21 00 00
B0 12 40 00
B0 13 40 00
B0 14 40 00
B1 14 40 00
B1 1C 40 00
B1 13 40 00
B1 12 40 00
B0 1B 40 00
B0 2B 00 00
B1 1C 40 00
B1 13 40 00
B1 12 40 00
B0 1B 40 00
B0 2B 00 00
B1 15 2E 00
B0 15 2F 00
B0 16 00 00
B0 17 00 00
B0 18 00 00
90 35 00 00
91 35 00 00
90 34 7F 00
91 34 7F 00
B0 16 00 00
B0 17 00 00
B0 18 00 00
B0 19 00 00
B1 17 00 00
B1 18 00 00
B1 19 00 00
B1 1A 00 00
B1 16 00 00
B1 26 00 00
B0 1C 00 00
B0 2C 00 00
B4 10 40 00
B4 20 00 00
B4 12 65 00
B1 1B 3E 00
B4 13 00 00
B0 1A 3C 00
B0 11 40 00
B4 14 64 00
B4 11 7F 00
B1 11 40 00
B1 21 00 00
B0 12 40 00
B0 13 40 00
B0 14 40 00
B1 14 40 00
B1 1C 40 00
B1 13 40 00
B1 12 40 00
B0 1B 40 00
B0 2B 00 00
B1 1C 40 00
B1 13 40 00
B1 12 40 00
B0 1B 40 00
B0 2B 00 00
B1 15 2E 00
B0 15 2F 00
geposted Mon 09 Jan 12 @ 6:44 pm
Unfortunately that ID conflicts with some models of the Vestax Typhoon, which is an official controller shipped with VirtualDJ LE.
Because earlier units such as the the Spin and VCI-100 MK2 were not really intended to be used with 3rd party software, they were released with firmware with the same SysEx ID, making it impossible to distinguish between them.
This may be why it is not working because VirtualDJ will think that it's a Typhoon.
If this is the case, your only option would be to make your own mapper for it to override the default. Please see: https://virtualdj.com/wiki/How%20do%20I%20map%20my%20MIDI%20controller.html
Or alternatively, sell it on eBay and purchase a newer controller that does not have this issue, such as the Vestax Typhoon or the new VCI-400.
geposted Tue 10 Jan 12 @ 1:26 pm
Hi,
Any news on the support of the vci100 mkII with virtual dj on mac?
i bought virtual dj 7 for my controlleur..and nothing work.
thanks for the help.
xl
xl
geposted Mon 09 Apr 12 @ 4:20 pm
Please register your Pro serial number on the page https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: https://virtualdj.com/buy/
Then follow the instructions above to rename the device if necessary to: VCI-100MKII DJ-Controller
If this doesn't work, then you probably have one of the conflicting models. You would either have to map it yourself manually or sell it and purchase a newer controller model that does not have this problem such as Vestax Typhoon or VCI-400.
geposted Tue 10 Apr 12 @ 6:16 am
dj_chrisson wrote :
VDJ does not recognise my new Vestax VCI-100 MK2 on my MacBook Pro, instead of the default VCI mapping it loads the default Vestax Typhoon mapping. On my desktop PC (Win7) VDJ recognises the controller correctly...I think that maybe the SysExID's of the VCI-100 MK2 and the Typhoon are both switched (or the same) in the default definitions of VDJ OSX.
If your controller is not recognized by Mac OSX? try to read this "BLOG"
Want to know the SYSEX ID, VID, PID of your controller in Mac OSX click "HERE"
geposted Tue 10 Apr 12 @ 6:52 am
I BOUGHT VESTAX SPIN 2 DJ CONTROLLER LAST 2016 AND THE UNIT HAS NO LICENSE ATTACHED, COULD IT BE TO GET THE OEM LICENSE?
geposted Tue 10 Jan 17 @ 1:12 am
The Vestax Spin 2 controller (or Plus) license for Virtual DJ 8 is $99. That entitles you to home use only.
For professional DJ use, you need either a full Pro (aka Infinity) license or a Pro subscription.
geposted Tue 17 Jan 17 @ 9:45 pm
