Forum: Old versions
Topic: VDJ Home crash on startup
Hi all,
I've just download VDJ Home (7.03) on a MBP 2010 model. As soon as I start VDJ it crashes (Error log below). Anyone know why this is happening?
--------- ERROR ----------
Process: VirtualDJ Home [26522]
Path: /Applications/VirtualDJ Home.app/Contents/MacOS/VirtualDJ Home
Identifier: com.atomixproductions.virtualdjhome
Version: 7.0.3 (7.0.3)
App Item ID: 417934534
App External ID: 3388883
Code Type: X86 (Native)
Parent Process: launchd [165]
Date/Time: 2011-04-14 19:01:45.140 -0300
OS Version: Mac OS X 10.6.7 (10J869)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x994d9250 strlen + 16
1 ...ixproductions.virtualdjhome 0x000a60a8 CForm::Resize() + 940
2 ...ixproductions.virtualdjhome 0x000a6b51 CForm::ShowPage(int, bool) + 527
3 ...ixproductions.virtualdjhome 0x000a6ca0 CForm::ChangePage(int) + 86
4 ...ixproductions.virtualdjhome 0x000ff34d CScreen::InitSkin() + 1169
5 ...ixproductions.virtualdjhome 0x000b848f CMain::OnCreate(void*) + 813
6 ...ixproductions.virtualdjhome 0x000b88db CMain::WndProc(void*, unsigned int, long, long) + 581
7 ...ixproductions.virtualdjhome 0x00137be7 main + 732
8 ...ixproductions.virtualdjhome 0x00024baa start + 54
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0xffffffff ebx: 0x00000000 ecx: 0x00000000 edx: 0x00000000
edi: 0x0000007e esi: 0x00bda3c0 ebp: 0xbffff788 esp: 0xbffff6cc
ss: 0x0000001f efl: 0x00010286 eip: 0x994d9250 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000000
Model: MacBookPro7,1, BootROM MBP71.0039.B0B, 2 processors, Intel Core 2 Duo, 2.4 GHz, 8 GB, SMC 1.62f6
Graphics: NVIDIA GeForce 320M, NVIDIA GeForce 320M, PCI, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.131.36.9)
Bluetooth: Version 2.4.0f1, 2 service, 12 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: AirPort, AirPort, en1
Serial ATA Device: OCZ-VERTEX2, 111.79 GB
Serial ATA Device: MATSHITADVD-R UJ-898
USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0x26100000
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8507, 0x24600000
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x06600000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8213, 0x06610000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x06500000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0237, 0x06300000
geposted Thu 14 Apr 11 @ 5:07 pm
What sound card are you using? I'm having the same type of problem and I was told how great VDJ was with Customer Support and they've given me next to nothing in regards to helping me resolve the issue. They had no problem taking my money though!
What is the size of your screen (in pixels)
Sorry to dig up this thread but same problem here, bot on 7.0.3 and now on 7.0.4
Macbook Pro 15' 2011 model, screen size is 1440x900.
However the crash doesn't seem to be related to the screensize, but to the filesystem. I use a case-sensitive HFS+. This makes VirtualDJ fail like above. Creating a non-case sensitive HFS disk image and putting VDJ there makes it work.
Exactly the same problem, Mac book 15" 2.4 GHz intel core duo, 4gigs ram, use to work fine then suddenly stop workin.....ive tried reinstalling it, even reinstalling my whole comp.. any help would be really greatful :D
bump
Please try this.
https://virtualdj.com/wiki/Mac%20Clean%20Re-install.html
Esp. this is a verý important step!
Delete the following file: MacintoshHD -> /Users/YOURNAME/Library/Preferences/com.atomixproductions.virtualdj.plist
Please delete ALL files they look like this.
It can be more then only one file ;-)
I had this problem but if you do what The support say its gonna work again .my soft is Working Well after this good luck!!!!!!
I have exacly the same problem
and can't find anywhere com.atomixproductions.virtualdj.plist that can be the problem why is crashing?
