Does anyone know if virtual dj has the option to use a microphone while broadcasting? If so how please
geposted Tue 19 Apr 11 @ 9:54 pm
Which version of VDJ are you using? Microphones are not support in the Home and Broadcaster editions of the software. For more information on configuring your mic, check out page 11 of the Audio Set-up Guide located here: https://virtualdj.com/images/pdf/VirtualDJ%207%20-%20Audio%20Setup%20Guide.pdf
Hope that helps.
Hope that helps.
geposted Tue 19 Apr 11 @ 10:15 pm
