I want to change the code of some of the plugins to make them easier to work with. Some of the effects I have have slider 1 for wet/dry, and some of them have wet/dry on the 2nd slider. I want to make the wet/dry slider always be slider 1. Also, I have a phaser that has a slider for LFO length. It starts at 8 beats and goes down to 1/64 beats. This isnt very useful. Is there a way to change the code so it instead starts at 32 beats and goes down to 1/2 beats?
Thanks
Thanks
geposted Sun 24 Apr 11 @ 4:08 am
geposted Sun 24 Apr 11 @ 5:13 am
You only need to change the data of the functions DeclareParameter() in the function OnLoad() of the class
For the second part, you have to modify this in the OnParameter(int id) of the class
geposted Sun 24 Apr 11 @ 5:44 am
