Hi recently purchased the hercules mk4 & it works great as I switch over to the digital world of djing. I have a question when I record my mixes how do I get them to record seperately so that I may skip to the next track instead of having a 80 minute continuance mix but don't have breaks or pauses in between the mix as I record it on the cd.
geposted Thu 28 Apr 11 @ 9:26 am
Sorry, this is not possible in VirtualDJ LE that comes free with the DJ Console.
VirtualDJ LE only supports basic recording into a single file.
For more advanced recording options (Split when crossfading), the ability to download and use custom effects, skins, etc. and much, much more, you will need to upgrade to the full VirtualDJ Professional.
Assuming that it is not second hand or the discount has not already been used, your MK4 DJ Console entitles you to a significant discount off upgrading to VirtualDJ Professional. To receive this, please go to https://virtualdj.com/buy/ and enter your DJ Console software serial number in the box provided.
geposted Thu 28 Apr 11 @ 10:43 am
