Forum: VirtualDJ Plugins
Topic: Effects and Sampler Problem in Virtual DJ 7.0.3
Hi,
I just bought VDJ Pro, i very much disappointed because some effects will not work. I also downloaded effects such as flanjet,looproll, ringmod, shaker_beats but it will not work. How to make the effects work on virtual DJ 7.0.3. Thanks in advance.
geposted Tue 03 May 11 @ 12:07 pm
beatbreaker1 wrote :
When you say no working you mean you installed them and there not showing up in the effects browser??
http://www.virtualdj.com/forums/95136/VirtualDJ_Plugins/Plugin_not_working__Controls_not_showing__DX_File_Missing_______Read_this_before_posting_____.html
Read that post, there are instructions on how to fix it if this is your problem.
Let us know if that doesn't work
Huey
Hi Beatbreaker1,
I can see it in the effects browser but when i click, nothings happen. by the way, are the dj beatbreaker in crooklynclan.net? Thanks for your reply. I am very much depress because i am excited to use this one. Thanks.
No thats not me, lol!! That lnik should help you out then. Try those and let us know.
Huey
Huey
hehehe. sorry, i thought you are. by the way, i un install my virtual dj basic, virtual pro, deleted virtual dj folder in my documents and c:\program files, then re install virtual dj pro. update my direct x from microsoft website. and now it runs except some effects but acceptable for me now. hehehe. Thanks a lot for the reply.
I bet the other ones that aren't working are audio effects?? If so hold I have to find the link.
Be back shortly
Huey
Be back shortly
Huey
Yes. its some audio effects.
Thanks Huey..
As said, it's a runtime issue 99% of the time :)
Hi SBDJ,
what do you mean by runtime issue? 99% of the time. please elaborate. thanks a lot.
hi i have virtual dj pro i want to download the effect of flanjet it say that (Your current licenses do not allow you to download Effects) why?
Only people that have purchased the programme can get access to most if not all of the plugins.
