This came up in another post, but anyway it would be very useful to be able to specify the length of time or the speed at which an auto cross goes from point a to point b smoothly like when using the pitch reset.
The example in the following topic was master volume reset with the press of a button, It makes sense that you should be able to specify the time after the value or the speed the fader will move for better coherency of sound. I envision something like:
deck 1 volume 100% 1000ms (time)
deck 1 volume 100% [+0.05%] (speed)
http://www.virtualdj.com/forums/147141/General_Discussion/Vdj_Script_Help_required__2_Questions__Gain___Volume_reset_.html
Cheers
Andrew
Cheers
Andrew
geposted Thu 05 May 11 @ 4:31 am
actually looking at speed again it doesn't really make sense... It should be distance over time so:
50%/2000ms
50% is how far the slider would move in the specified time, or maybe it could be standardised to make it so that brackets or something similar make the value over say 1000ms
that would mean the code should look something like
deck 1 volume 100% [25%]
meaning if the fader is set at 0% it would take four seconds to reach 100%
50%/2000ms
geposted Thu 05 May 11 @ 11:07 pm
