Ok, the issue I'm having seems to be that you can only select single folders to scan for BPM's, and while it's fine to select my entire library, the detection process takes DAYS.
Is there a way to select multiple folders (pick and choose sort of thing) for a BPM scan, or perhaps omit folders from the scan, which is really what I want to do.
For example, if I remove the folder from the search database, does it still get scanned if I select the top level folder it resides in?
Any help would be appreciated.
-Mtown
-Mtown
geposted Thu 05 May 11 @ 10:01 am
The easiest way to scan songs is to create a filter folder that only displays songs in your database that need scanning.
Please see https://virtualdj.com/homepage/jpboggis/blogs/3972/Pre-analysing_your_music_collection.html for details.
geposted Thu 05 May 11 @ 1:11 pm
Awesome! This works great, and being introduced to the filter functions will help me with some other issues. Thanks for the Quick Response!
-Mtown
geposted Thu 05 May 11 @ 2:44 pm
