Ok this problem only started once i had update to version 7.01 i think it is, anytime i right click a song/folder and want to analyze it for bmp's it starts as usual then cuts off after about two seconds. however if i manually load the songs onto the deck it fetches the bmp no bother. any help would be much appreciated.
geposted Fri 06 May 11 @ 3:26 am
vdj is up to 7.04 now, you should register your serial number so you can upgrade to the latest version, that should fix the problem.
https://virtualdj.com/users/edit.html
geposted Fri 06 May 11 @ 3:36 am
