hi i need help find asio driver for my mac book os x 10.6 for denon 6000 where can i go for them thank you---Dj Aurora AKA Arturo
geposted Sat 07 May 11 @ 8:13 am
Mac doesn't support ASIO. It uses core audio instead. The MC6000 is core audio compliant. Make sure that you have set the switch on the back of the MC6000 to Mac.
geposted Sat 07 May 11 @ 12:50 pm
thank you some much for your help
geposted Sun 08 May 11 @ 3:50 pm
hello anyone can ns6 and virtual dj work and how can i do so plz help thx
geposted Sat 11 Aug 12 @ 11:22 pm
You will need to upgrade to the latest VirtualDJ Professional to be able to use it. It's natively supported in the latest version: https://virtualdj.com/wiki/VirtualDJ%20Controllers.html
The LE versions you have now will only work with Hercules DJ Console RMX or MK2.
You can upgrade from the RMX version to the full Pro at a considerable discount by going to https://virtualdj.com/buy/
geposted Mon 13 Aug 12 @ 5:24 am
i have my mac and when i install the virtual dj it cant read my unmark mix deck i don't know if its the drivers or what because i tried with pc too but its not helping.
geposted Thu 20 Dec 12 @ 12:42 am
Hi,
please have a look here:
https://virtualdj.com/wiki/MixDeck.html
PS:Please open next time a own topic ;-)
geposted Thu 20 Dec 12 @ 3:03 am
I have an Denon MC3000 that works fine with a PC. I just bought a mac Book Pro and it will not recognize the controller. i know ASIO does not work on MAC can anyone tell me how to get a driver for the MC3000 for MAC.
Thank you very much,
Ed
Ed
geposted Sun 01 Dec 13 @ 9:13 pm
There is nothing additional needed. ;-)
Inputs: None
Ouputs: Headphones (Master: Chan 1&2 / Headphones: Chan 3&4)
Sound card (Mac): 4-out card ------> Choose beside MC3000 in the list
Inputs: None
geposted Mon 02 Dec 13 @ 6:36 am
I did an update for virtual dj 5 djc and now my hercules rmx doesn't connect. Here is my serial number: *************. What do I do? Please help, thanks.
geposted Mon 24 Mar 14 @ 7:51 pm
Please do not post in public any serials of the software. !!!
Serial is removed from your post.
geposted Mon 24 Mar 14 @ 10:42 pm
Hey Virtual Dj Team,
I making a transition from pc to mac. Currently I have Denon HC4500 with virtual Dj Pro 7. Is there any update needed to install Denon drivers to Macbook Pro and do I need an update from my Virtual Dj Pro 7 version. Any info. will be greatly appreciated. Thanks.
geposted Sun 20 Apr 14 @ 2:26 pm
The HC4500 doesn't need any drivers on Mac - It works using native Core Audio. ASIO is Windows PC only. Please see https://virtualdj.com/wiki/DN-HC4500.html
Please also register your VirtualDJ Pro serial number to your account and download the latest v7.4.1 version.
If you have not purchased VirtualDJ, then please support the software and its future development by purchasing it (Especially if you are a working DJ and you are making money as a result of using it at your gigs.)
geposted Mon 21 Apr 14 @ 11:18 am
Hi virtual dj team....i changes from pc to mac so i have virtual dj le with my macbook pro .
i connect all, but when i want to connect my controller to my ampli theres nothing happening in my mac or vms2. i go to where i bought my vms2 ans told me it was virtual dj problem.
thx
thx
geposted Mon 27 Oct 14 @ 4:26 pm
Prezados,
Boa noite !
Preciso de ajuda para configurar a pré escuta da minha controladora DDJ RB que utilizo com o Virtual DJ.
No aguardo desde já.
Boa noite !
geposted Sun 11 Mar 18 @ 1:29 am
