Hi everyone,
Is there a way to change the standard vdj arrow from "Black outline in white" to another color.
My standard computer cursor arrow is "White with Black outline" so I know that VDJ does something to change this.
My reason for change this is simple... This past weekend while doing an event it was very hard to see the cursor arrow out in the light of day. While I was able to see my music ok at times I thought my system was down because I couldn't the arrow.
I hope you can help.
Like always, thanks for letting ask this easy, but important to me, questions...
geposted Sun 08 May 11 @ 7:54 pm
Download Cel's Registry device. It has a "white Cursor" option. https://virtualdj.com/addons/2170/Registry_Tool.html
geposted Sun 08 May 11 @ 7:58 pm
A day skin is always useful :)
https://virtualdj.com/addons/11597/TCmania_Bright.html
https://virtualdj.com/addons/4416/Turntablist___Outdoor.html
geposted Sun 08 May 11 @ 9:29 pm
If you are using a mac,you can:https://virtualdj.com/forums/142692/MAC_Version_Technical_Support/Out_Side_Skin_Is_Now_Ready_.html?search=out%20side&page=1
geposted Mon 09 May 11 @ 12:52 pm
Sorry no Mac here...
TearEmUp, Thanks I will try this today...
Thanks everyone for your help...
geposted Sat 12 Nov 11 @ 6:47 pm
TearEmUp,
Question about Registry Tool...
Since all I really want and need is my Cursor to be white do I clear all and only leave the option for WhiteCursor and then Apply...???
I don't need or want any of my other settings to be effected...
The Registry Tool Dialog is full of items I really don't know about and don't want to mess around with.
Thanks
Thanks
geposted Sat 12 Nov 11 @ 7:02 pm
Don't sweat the terms. They don't effect operation in a negative way. Cel's tool is OUTSTANDING!
geposted Tue 15 Nov 11 @ 9:25 pm
Thanks TearEmUp,
I will make the change this Monday...
geposted Wed 16 Nov 11 @ 1:26 pm
